Old 10-16-2013, 05:25 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Ignition Jumper for impulse Mag?
The instructions for the ACS Ignition switch indicate to install a jumper on the #1 terminal when "left mag is retard breaker mag or has impulse coupling"
My engine has dual impulse magnetos (both). Is this jumper (or some other configuration) required?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 10-16-2013, 05:53 PM
rocketbob's Avatar
The jumper disables the right mag when in the start position. With two impulse mags you remove the jumper so both fire during start.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-16-2013, 07:25 PM
Dbro172's Avatar
Default Thanks.
Thank you
Derek Hoeschen
EAA Tech Counselor
