Thanks for the suggestion
I'm leaning toward a solution like yours without a guide tube for stowing the strut.
It would be a strip attached to the rear bulkhead (and flat, so my nice leather upholstery doesn't have to be modified), that extends up to just below the fuselage skin overhang, angles to parallel it, then angles again to present an attachment point for the bottom end of the strut that is perpendicular to it.
The strut supplied with this kit has #8-32 threaded ends. The upper end has a a positive twist-to-lock action that connects to the slider-block, and the other end could rest on the top of the support with a thumbscrew inserted from below to secure it.
A work in progress, to be sure, but what isn't with airplanes?
Thanks again,
Tosh
Tango Mike
Bucket List Builder Wannabe
RV-6 N221P (sold)
RV-4 N221TM (sold)
RV-7 N7721P
Dues Current through July 2017, double the minimum gladly paid in spite of DR's offer to waive them for veterans.
