Old 10-14-2013, 06:36 AM
Tumper's Avatar
Tumper Tumper is offline
Default Rudder anti-collision and position light wire protection
Gentlemen and ladies, how did you protect the wire from chafing and weather as it exits the HS and enters the rudder? Any pictures? I apologize if this has previously been discussed.
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 10-14-2013, 08:47 AM
Rupester Rupester is offline
Where the bundle passes thru the slot in the front face of the rudder bottom, I put three layers of heat shrink. I also glued a split piece of tygon tube onto the bottom edge of the slot in the rudder bottom. One yr and 100hrs later ... no evidence of chafing.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 10-14-2013, 09:01 AM
Low Pass's Avatar
Low Pass Low Pass is offline
My wire passes though the aft fuselage and into the lower rudder. It's double insulated three conductor. It passes loosely though a 1/2 hole. Has worked fine for 13.5 yrs and ~1600 hrs. No grommets or other prep of the holes.
Old 10-14-2013, 09:02 AM
bruceh's Avatar
bruceh bruceh is offline
I cut a slot across from where the wires leave the fuselage, and inserted a rubber grommet.
You could also try to use caterpillar grommet in the same way. Just make sure you can get your wires and connector through the slot.
Bruce Hill
2020 VAF donator
