Old 10-14-2013, 03:49 AM
rleffler's Avatar
rleffler rleffler is offline
Default Mechanical fuel pump pressure?
I'm looking for the amount of fuel pressure that the mechanical fuel pump (engine attached) on a yio-540-d4a5 is supposed to yield. Aircraft Spruce's listing states 25-30psi. Is this what I should expect?
The reason I'm asking is that mine is only generating about 23 psi.
Is there any effective way to test, short of taking it off and sending back to Lycoming or a certified shop?
Bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-14-2013, 08:54 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
My IO-360, Same pump??? It does 20psi at full power and 22 to 24 in cruse, the pump it replaced was the same.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 10-14-2013, 11:54 AM
rleffler's Avatar
I found the answer, it's 14-45 psi. I've ben told by several sources I don't have an issue at 23 psi.
bob
Bob Leffler
Old 10-14-2013, 01:08 PM
Walt's Avatar
Walt Walt is offline
The fuel pressure spec for the Precision Silver Hawk is 20-50 psig.
Lycoming spec for IO engines is 18-28 psi.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
