Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 10-13-2013, 10:18 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Hartzell Propeller o-ring lubrication recommendation
Anyone have a recommendation for lubrication of the prop o-ring when installing a Hartzell constant-speed prop?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 10-13-2013, 10:23 AM
Toobuilder's Avatar
Engine oil.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-13-2013, 10:28 AM
rv8ch's Avatar
Default Hartzell Prop o-ring lube
Thanks Michael.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 10-13-2013, 10:33 AM
Toobuilder's Avatar
Sure thing.
Unless dictated otherwise by technical data, its generally safe to use the same fluid the system uses as oring lube. Engine oil, hydro, and in the case of fuel, Vaseline/petrolatum.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
