Old 08-29-2006, 10:19 PM
MrNomad's Avatar
MrNomad MrNomad is offline
Default Advice please - Stratomaster Ultra Horizon XL
Does anyone have any experience with a product known as
The Stratomaster Ultra Horizon XL
The State of the Art in monochrome glass cockpit
Sold by www.SportFlyingShop.com
Looks similar to the Dynon product at a much lower cost.
Thanks.
Old 08-30-2006, 12:19 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Hey MrNomad,
I know the company since they are in my back yard, No experience on that product, but they have a new one in the pipeline that functionality wise kicks the Dynons but for the same price, Efis, engine monitor, GPS all in one colouer package for $2,000 - $3,000. I still haven't seen the thing in person but read about it over here:
http://www.vansairforce.com/communit...ead.php?t=8422
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 08-30-2006, 03:46 AM
Pirkka Pirkka is offline
Not sure about your rules there but here in Finland it's required that the gauges (type not defined) should have color indications like green, (yellow) and red areas (I don't remember exact phrase how it's said there). There is currently one plane having monochrome display with special permission to gain information is this current rule up to date or can it be loosened. Yes you read right, we have only 5 million people here and just one plane has monochrome display so far.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 08-30-2006, 06:03 AM
rv9aviator rv9aviator is offline
I bought one of their CHT-EGT monochrome gages and I could barely read it in normal daylight. I am assuming they have changed the display, but look before you buy. I'm not trying to run down their product as it worked fine except for the display.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 08-30-2006, 04:24 PM
MrNomad's Avatar
Default "...could barely read it in normal daylight"
That's what I'm afraid of. Dynon recently boosted their screen to make it more readable in sunlight. The acid test of the Dynon took place in Tucson. We rolled the plane into bright sunlight, opened the canopy to make it even harder on the unit, but I could still read it easily.
I'll check CHT-EGT to see if they addressed this issue which in an RV in the southwest, is kind of important.
Thank you.
Old 08-30-2006, 11:50 PM
I have one of their CHT-EGT monochrome gages in an open cockpit microlight trike and I CAN read it in daylight.
I guess the best is to check it out yourself, People's perception and vision of what is acceptable is different.
Regards
Rudi
Old 08-31-2006, 12:49 AM
I have just visited Jeff's very nice website, and saw he is using some MGL Instuments, go here:
http://www.jeffsrv-7a.com/PANEL.htm
Here is his panel with MGL instruments (Used without permision)
Maybe contact him and see what he thinks...
Kind Regards
Rudi
Old 08-31-2006, 05:10 AM
Rudi, the screens appear to have a green background in the picture. Mine had a gray background. They may have changed the screens over the last couple of years.
Jim Wright
Old 08-31-2006, 06:53 PM
Phyrcooler's Avatar
Phyrcooler Phyrcooler is offline
Default Check With Tony Spicer
I believe that these are recommended over in the Sonex land and pretty popular... You might check with some of those folks. It seems like a pretty good VFR setup if it is indeed reliable and readable.
Unfortunately, compared to this website, the one that the Sonex folks use (Yahoo, I think) really doesn't compare.
Tony has/had? a Sonex, and I believe is also on this site from time to time.
dj
