Old 10-12-2013, 01:11 PM
bill v bill v is offline
Default what makes a good thin shim
i have all the thicknesses of aluminum sheets .016, .025, .032 etc. but what makes a good aluminum shim that is less then .016? I would like about .010 or less
built rv-4 started 1987 finished 1996 now building rv-7, fitting cowl
Old 10-12-2013, 01:16 PM
jrs14855 jrs14855 is offline
Default shims
Stainless steel strips available from some hardware stores and most hobby shops.
Old 10-12-2013, 01:34 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
0.016 or 0.025 and a sanding disk on your die grinder....
Usually I found that when a shim that thin was required, a tapered shim would work better - easy to create with the die grinder.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-12-2013, 01:40 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default shims
pop cans work pretty good
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 10-12-2013, 02:50 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Go to NAPA auto, they will have steel and brass shim stock in various thicknesses.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-12-2013, 07:17 PM
RVDan RVDan is offline
Shim stock is available down to .001" in SS and .0015 in aluminum. If the NAPA store doesn't have what you want, try MSC.com a machine shop supply company.
Dan
Old 10-12-2013, 07:34 PM
Geico266's Avatar
Geico266 Geico266 is offline
Yea, right.
Like any self respecting builder would be drinking pop. Beer yes, pop, not so much.
Brass shim stock works well also. I bought a selection of it years ago and it has served me well with a dozen different thicknesses.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-12-2013, 07:49 PM
BillL BillL is offline
I know the OP asked about aluminum, but if harder materials are needed, steel feeler gage sets can provide some needed material. Just get a cheap set and you get assorted thicknesses.
Bill
RV-7
Lord Kelvin:
Old 10-12-2013, 10:25 PM
krw5927 krw5927 is offline
Your local home improvement store has small pieces of aluminum roof flashing. I got mine at one which begins with "L" and rhymes with "bows". The flashing is .008" thick by my micrometer.
Kurt W.
RV9A
FLYING!!!
Old 10-13-2013, 06:02 AM
Captain_John's Avatar
Use Hysol Liquid shim.
Google it up.
. CJ
The experiment works!
