Old 08-29-2006, 06:09 PM
drakerv drakerv is offline
Default Master solenoid gets hot
Has anyone noticed their master solenoid getting hot while testing panel instruments and radios on the ground. Thanks
Marc
Old 08-29-2006, 06:31 PM
SteinAir SteinAir is offline
Don't worry.....it's quite common.
Stein.
Old 08-29-2006, 06:42 PM
glenmthompson glenmthompson is offline
Default yep..
Yep, normal..Every one I have seen gets really warm. Ever wonder why the battery runs down so fast with the master is left on, and nothing powered?
The heat worried me the first time I saw it too. (Almost as hot as an RV-10 tunnel...haha..sorry, could not resist.
Glen
Old 08-30-2006, 07:33 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Ouch
Yea it draws 3/4 to 1 amp at 14.5 volts. That is 11-14 watts. It kind of sucks to use all that electricity to just hold the battery contactor.
I looked into 5 ways to eliminate this device or replace it, but bottom line it is cheap, works and is pretty fail safe. You can upgrade to a kilovac $150 magnetic semi-latching heavy duty relay, which only uses milliamps to remain close, but not sure it's worth it. Just the nature of the beast.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
