Where should I be looking to determine the part numbers for the pad covers I need? I'm about to move my engine over to a closer hangar, and will take the opportunity to remove the fuel pump, mags, vacuum pump... basically everything, since they're all going to be swapped out anyway. Obviously having gaping accessory case and mag mount holes where everything used to be is not very conducive to refilling the engine with pickling oil.
The engine is an IO-320-E1A, and from other Googling this morning, I *think* the following ECI p/n's apply:
- Vacuum pump pad cover: Lycoming 60430, ECI AEL60430
- Prop governor pad cover: Lycoming 65109(?), ECI AEL65109
- Engine fuel pump pad cover: ECI AEL65098 or AEL65087 (AC fuel pump) or AEL60431 (AN fuel pump)
But how do I determine which fuel pump type I have, and what about the mags? What else might I be missing?
Thanks!
