Old 10-08-2013, 04:07 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
Default How Much ACF 50
It has been just over a year since painting and am looking to spray the inside with ACF 50. I see it comes in two sizes - 1 Qt and 4 Qts. I suspect 4 Qts is way too much so is 1 Qt enough or will I need 2?
I plan to apply it with a quality garden pressure sprayer with Viton seals as the commercial equipment is so expensive. Anyone have similar experience and tips?
Bob Ellis
www.rv-8.co.uk
G-JBTR Having a ball flying this wonderful machine
Donation July 2016
Old 10-08-2013, 06:36 AM
Levrie Levrie is offline
Default You won't even need a quart"
Hello Bob,
I have purchased an aerosol can of about a litre here in the UK. You won't need anything like a quart!
The trick here is that a little goes a very, very long way, it will seep out of every orifice you can think of, so the finest spray with the minimum amount is my advice, otherwise, your beautiful aircraft will look as if its leaking!!!
I bought mine from a Biggin Hill supplier, (transair I think).
If you ask them nicely, they may even send you a trial pack free to evaluate.
Warm regards
David Richard
Old 10-08-2013, 02:47 PM
Bob Ellis's Avatar
Thanks for that David - just the info I'm after. Looks like the motorcyclists are into it now so the keenest prices seem to by cycle shops on eBay. Regards Bob
Old 10-08-2013, 03:32 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Atomizing the spray is the standard method. You won't need the total qt. if you do it properly. You want the mist as fine as you can get it. It will go into every joint and weep on the floor for months!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
