Old 10-06-2013, 06:21 PM
Greg Arehart's Avatar
Default Inexpensive hangar building?
I'm looking for options for a relatively inexpensive hangar that will be erected in far NW BC near my cabin. Probably need something like 40 x 30 feet. I've looked online a bit at the fabric hangars as well as quonset-hut type. I'm wondering what information anyone might have out there as to price (hard to get a quote on most of this stuff without signing away all my personal info) and suitability for a polar climate. I would probably put this on a gravel/dirt floor with minimal foundation (or as minimal as possible since concrete is ~$250/yard).
The goal is to have a place to store the airplane during summers, and store a boat & truck in winter (the airplane will likely come back to Reno with me each winter).
Thanks for any thoughts/info,
Greg
Greg Arehart
N 7965A
Old 10-06-2013, 06:29 PM
N941WR's Avatar
N941WR N941WR is offline
You can always try one of these metal carports and box in the sides and ends. For $5400, that is not a bad deal. Of course, the additional siding and doors will cost more.
Playing with that website, it is easy to double the price if you option it up.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-06-2013, 06:30 PM
Randle Randle is offline
Had mine built, 30x40 steel weld up for $17000 and that includes the $6000 for the slab. That does not include the electrical and the big door. Just to give you an idea.
If you are 90% efficient, and your buddy who checks the 10% you missed is also 90% efficient, together you're 99% efficient.
RV-7A - empennage done minus glass
wings nearing completion
Old 10-06-2013, 06:56 PM
hydroguy2's Avatar
I've been collecting bids on pole building type hangars around here.
a 50x50 clearspan 12' sides with one end open for a 44x12 door was ~$32K with some overhangs and wainscot, Erected on my leveled site.
another 40 x50 x12 pole building normal trusses was $22500....(overhangs and wainscot optional fee)
so roughly $11-12/sqft gets an erected shell, no dirt work, power or anything else. in NW Montana
Old 10-06-2013, 07:49 PM
Bill_H's Avatar
Bill_H Bill_H is offline
See here... http://www.vansairforce.com/communit...d.php?t=102000. I would NEVER do a Quonset style again.
Old 10-06-2013, 08:13 PM
rv7charlie rv7charlie is offline
If you're motivated to DIY, you can build a variation of a pole barn really inexpensively. I added a 30x50 lean-to to my hangar using 4x4's as the posts & 9" tall steel purlins (what you see between the steel beams in big metal buildings) as the beams (rafters). I built the entire structure without assistance, except a 2nd guy on the gas post hole digger. The metal purlins are what allowed my solo build. A 31' purlin is light enough to lift one end onto your shoulder & walk up a ladder with it to sit it on top of the post.
You'd need to tweak the design a bit to allow for your snow loads, but no reason that it wouldn't work up there.
PM me if you'd like more info.
Charlie
Old 10-07-2013, 12:01 AM
Beancounter Beancounter is offline
Default hangar
Greg
Consider using sea cans (modular shipping containers) topped with roofing trusses.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 10-07-2013, 06:28 AM
n981ms's Avatar
n981ms n981ms is offline
Default Quonset?
For cost concerns I think they are worth considering. I got a good deal on ours. I am not as negative on them as Bill but they do have issues.
1. You will not likely set it up with ropes and a scaffold as in there instructions. We used a scissor lift and set up one half of each arch at a time. After the first two full arches are up it goes fairly smoothly.
2. Lots of bolts. I found that with a small battery powered impact wrench that I could tighten almost all of the nuts from inside the hangar by myself. Zip, zip, zip. Without anyone having to hold the outside head of the bolt. Marked the ones that would not and got some help on those. I would not attempt one of these buildings without the investment in this tool.
3. Mine leaks a little. I could probably fix but have not.
4. Door issues as mentioned. I built a custom hydraulic door with slanted jams to maximize width and height.
Starting from scratch today. Probably would go with a more traditional building.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
Old 10-07-2013, 10:22 AM
flyboy1963's Avatar
Default ah, the ultimate quest
...lots of interesting ideas here, I had a few, so sent you an e-mail.
I guess it will all depend on what you can actually get trucked to your site eh?
( or barge up Teslin lake?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
