Old 10-06-2013, 12:39 PM
Dan.Pat.B@gamail.com Dan.Pat.B@gamail.com is offline
Angry GRT Fuel Gauges
First flight of my RV-7A was 8/6/09 after 6.5 years of built time - now have 431 hours on the clock - It's equipped with a GRT, dual screen, single AHARS system - with one exception GRT system has been trouble free - the exception has been the fuel gauges - I installed capacative sending units in the tanks at time of construction - converter units are under the floor under the seats - I've never been able to get that system to work properly - GRT suggested several things - didn't work - an engineer friend of mine programmed capacative values into the converter units to reflect different fuel levels - this worked after a fashion but fuel levels shown are way, way off the mark - anyone have any experience with this system - if so how did you program it - if you had problems with it how did you solve it - I don't relish the thought of removing the tanks and installing resistive type float units - I'm about to admit defeat and install an EI capacative type dual gauge (EI FL-2C) from Vans -
Dan Bergeron
RV-7A - N307TB
431 khours since first
flight on 8/6/08
dan.pat.b@gmail.com
Old 10-06-2013, 12:58 PM
Bevan Bevan is offline
Are you running 100LL or other?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
