08-30-2006, 11:19 PM
Thanks for the info
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
04-11-2007, 12:43 PM
fuel lube?
It was recommended to use "fuel lube" on the threads of the fuel tank-drain.
I went to Canadian-Tire (a Canadian automotive store) and asked about this, but they hadn't heard of "fuel lube". I searched the shelf of lubricants but found nothing that was advertised as being for fuel system components.
What is a suitable lubricant for this? Also perhaps for lubricating the rubber seal on the fuel-cap ?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
04-11-2007, 12:56 PM
Dan Checkoway RV-7
04-11-2007, 01:04 PM
Second Dan's recommendation.
The tube is enough to do a bunch so you don't need the can.
04-11-2007, 01:15 PM
Is that stuff the same as an extreme-temperature graphite lubricant?
Phil
RV9A (SB)
Ottawa, Canada
04-11-2007, 01:19 PM
Don't believe so. It's a clearish/translucent goop.
Dan Checkoway RV-7
08-02-2012, 08:05 AM
Parker O-ring lube is not the answer. It must dissolve when fuel touches it. Mine are dry again after a couple of days after using Parker O-ring lube. I'll switch to EZ turn.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
08-02-2012, 10:54 AM
I use Lubriplate. Clean and re-lube at annual.
Haven't changed the "O" rings since the "new" caps came out sometime in the 1990's.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-31-2012, 03:09 PM
How about Permatex?
I have the same question in regard to the fuel line fittings that are to be installed on my fuel pump. The Manual says to use "Fuel Lube" on the fittings.
As an alternative to no-longer-available "Fuel Lube", can I use high-temperature Permatex? That's what I've been using as a sealant on the other lines. Is this acceptable?
Rob Erdos
Ottawa
RV-6 some day...
12-31-2012, 03:27 PM
It is available - fuel Lube is now EZ Turn ( http://www.aircraftspruce.com/catalo...?clickkey=9406). Same thing.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
