Old 10-06-2013, 10:59 AM
rocketbob's Avatar
Default Garmin Pilot question
I've been playing around with Garmin Pilot on my iPhone, iPad, and the Android version on a Galaxy Note.
On the iPad, it allows me me to turn on the Nav Bar at the top but the iPhone and Android versions do not. I assume it only is allowed to be turned on something with a larger display like a Nexus 7 or iPad. For me this is a vital feature, to be able to see distance to next waypoint, track, bearing, etc.
Since the Galaxy Note is almost the perfect size to replace a Garmin 496 is there a way to turn on the Nav Bar?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-06-2013, 11:33 AM
DougJ's Avatar
DougJ DougJ is offline
I have GP on a Nexus 7 and it has a user configurable nav bar. You can choose how many items you would like, and what you want each item to be.
On the Nexus 7, in portrait mode, 5 items fit across the top. I have mine set for ten total, a quick swipe left or right enable you to use all ten. It works great.
I don't think it even gives you the option for the nav bar on smaller devices, but you can see if it's available under Settings > Map. If it's available you'll see an on-off radio button and a selection for the number of items to show.
Doug
Old 10-06-2013, 11:56 AM
rocketbob's Avatar
My point exactly...can't turn on the nav bar on smaller devices.
N8155F C150 flying
