Old 10-06-2013, 06:52 AM
pierre smith's Avatar
Default Fuel injection problems yesterday.
Coming back from the Race to Ridgeland in South Carolina yesterday, my -10 suddenly showed highly elevated EGT's for no apparent reason. I had been running 23"/2350 RPM and ROP, around 1330 EGT and all of them suddenly went to 1410/1430 without me touching anything. I had been running 15.4 GPH, so I enriched the mixture to lower the EGT's to near 17 GPH.
They did come down a little, to just under 1400 degrees with fuel flow at 17 GPH. The CHT's had not risen at all during this episode, so I suspected a Dynon problem. (D-120 EMS).
I also considered the fact that I may have developed a fuel leak under the hood, so I braced myself for a possible in-flight fire and was ready to shut the fuel off. If the engine was truly starving at 17 GPH, all of the fuel must not be reaching the injectors, hence the high EGT's, no?
I remembered Todd Swezey's cockpit fire and explosion at Ridgeland a few years ago, so I decided to NOT touch the flap switch in case there was fuel in the tunnel, and landed fast and long at home.
I will de-cowl the airplane and I'll report back.
Opinions anyone?
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 10-06-2013, 07:02 AM
plehrke's Avatar
plehrke plehrke is online now
What was the reason for enriching? Was it just to see what would change? EGT of over 1400 do not mean anything is wrong. When you enrichened what did the CHTs do?
Philip
RV-6A - flying 970+ hours
Paid dues yearly since 2007
Old 10-06-2013, 07:18 AM
Philip, the EGT's were at peak...not good, so I enriched it to lower them. Strangely, the CHT's hadn't changed during all this.??? The puzzling thing is that all of the EGT's rose simultaneously without me having done anything, by almost 100 degrees.
Best,
Rv10 Sold
Old 10-06-2013, 07:29 AM
Weasel's Avatar
Weasel Weasel is offline
Default mags
Did it run rougher when this happened? If 1 mag goes dead it will do this . Or if the timing somehow changes.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 10-06-2013, 07:30 AM
Walt's Avatar
Walt Walt is offline
Check the igition system, one of the mags died.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 10-06-2013, 07:32 AM
rzbill's Avatar
rzbill rzbill is offline
Pierre,
Isn't that a symptom of one ignition going bad? Ah, others beat me to it.
Bill Pendergrass
ME/AE '82
Old 10-06-2013, 07:54 AM
Default Hmmm...
Y'know, I was limpimg home with only 11.5 volts showing and it may well have been the Lightspeed failing,,,hmmmmm? Yep, it was also accompanied by a loss of several MPH, but I thought that the Lightspeed only needed aroun 9 volts, no?
Yep....could be.
Rv10 Sold
Old 10-06-2013, 08:54 AM
Yep....could be.
11.5 volts, Pierre?
You've got an electric problem not a fuel injection problem.
I've had EI and it comes with a double edged sword, its good when all is well but can get mighty weird when all is not well.
Good luck in sleuthing out the problem, with the alternator up and running it may be fixed.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-06-2013, 09:24 AM
Toobuilder's Avatar
My first thought would also be ignition. I've had one side die in flight and that's exactly what my EGT did as well.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-06-2013, 09:34 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Pierre,
I think you might be dealing with two issues. The lightspeed will work on 11.5 V but, it sounds like you lost your alt and could have spiked the lightspeed box. Seen it happen a few times. Also check the wiring to the coils for arc at the connectors. A dead Mag will cause the EGT issue, but does not explain the 11.5 volt issue.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
