09-30-2013, 02:44 PM
brake leaking
I have noticed that my left brake has been soft..so today I took it apart to investigate. First the flare at the bottom of the line had broken again....I thought that was easy and would be done. I ended up removing the whole thing an noticed the cylinder was pushed all the way out and was crooked...I took my C clamp and pressed back in. Put it all back together, bled the brakes, thought I was good to go..but then noticed a slow leak, drip from the bottom, from the leaky clinder (bad oring). So I am assuming the broken flare got into cylinder and disturbed the oring.
what are my options?..buy a new one, overhaul this one... I can't find the number for cleveland brakes on the web anywhere. Vans said to call back later and talk to techs.
pic
https://mail-attachment.googleuserco...1708d0ec75086b
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
09-30-2013, 03:47 PM
Thought I would answer my own question here.. I used compressed air to blow out the cylinder. The oring was damaged. I replaced it, put all back together, and problem solved.
Ryan Allen, CFII
E-170/175
10-01-2013, 04:29 PM
Brake line
Hi Ryan,
Just a suggestion. Have you thought of replacing Vans rigid lines with the flexable lines with SS braid from Summitt or JEGS? all my lines in my RV7 are flex except the short ones in the cockpit for fuel from the selector valve. No leaks, seeps or drips once installed. also much easier to replace brake pads as you can manipulate the brakes once unbolted from the wheel. No need to disconnect the line to change pads ;-)) Just going through this issue on the RV1 as my right brake started seeping due to a bad O ring and I have rigid lines on The Mocking Bird.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
10-01-2013, 06:00 PM
You might want to think about doing the other side. It can't be far behind.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
10-01-2013, 06:16 PM
Yes,I have considered and will be replacing the lines with SS braided type in the very near future, wish I would have sooner.
Ryan Allen, CFII
E-170/175
10-01-2013, 06:50 PM
I have upgraded pucks and Viton o-rings for sale.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
10-01-2013, 07:46 PM
The upgraded stainless brake lines are definitely a great improvement and will last for a long long time.
If you have any questions, please feel free to contact us.
Have a great day,
Steve
