Old 09-30-2013, 09:31 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Default Question: Rule of thumb pertaining to bolts
I know that there is a rule of thumb about the alignment of bolts that goes something like, Top to Bottom, Front to back. Is there a preference when a bolt is set laterally across the plane?
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 09-30-2013, 09:45 AM
jdeas's Avatar
jdeas jdeas is offline
Default Out
If not defined in the drawings, threads pointing outboard
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 09-30-2013, 10:47 AM
Put the head on the higher side, if dihedral is present.
In general, the idea is that if the nut should fall of, the bolt shouldn't fall out.
Dave
Old 09-30-2013, 10:58 AM
az_gila's Avatar
az_gila az_gila is offline
..or backwards...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-30-2013, 11:12 AM
Tom Martin Tom Martin is offline
Generally,
Threads in, towards the centre line
Threads back, towards the tail
Threads down, towards the ground
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 09-30-2013, 04:09 PM
Ironflight's Avatar
VAF Moderator / Line Boy
And remember - these aren't "laws"....they are more like "guidelines" - there are numerous exceptions (if the reasons are good).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-30-2013, 08:13 PM
Lemmingman's Avatar
Thanks for all the answers. Is accessibility for inspection considered a good reason?
Gil Brice
Old 10-01-2013, 05:16 AM
Jesse's Avatar
Jesse Jesse is offline
Yes, accessibility for inspection is a great reason on some bolts. For example: on a zenith 801 there is a pushrod for the flaperons inside a channel in the fuselage with a bolt that connects it to the flaperons. I put the nut on the outboard side so I can verify it's still there and hasn't loosened during preflight. Seeing the head of a bolt has much less value on inspection than seeing the nut.
I have always heard that the threads should point inboard, but one reply is saying the same and another is saying the opposite.
Jesse Saint
Old 10-01-2013, 08:06 AM
flion's Avatar
flion flion is offline
One consideration I use - can I put a wrench, preferably a socket, on the nut? I don't want to be holding a nut and spinning the bolt if I can avoid it.
EAA Technical Counselor #5357
