Old 09-29-2013, 04:37 AM
Smilin' Jack Smilin' Jack is offline
Bob,
While not flying yet I copied a location that a buddy has on his RV6 which he flies IFR all the time, we both but the antenna on the aft bottom fuselage with the cat whiskers just behind the horizontal Stab so you don't run into them while walking around the plane
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 09-30-2013, 04:01 PM
DanBaier's Avatar
DanBaier DanBaier is offline
...underneath by the tail ....
Has worked very well with a GNS430.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 10-08-2013, 08:10 AM
bjdecker's Avatar
bjdecker bjdecker is offline
I've been using a Bob Archer VOR antenna in left wingtip, connected to a Micro Circuits 3-way splitter; ZFSC-3-4+ (similar to COMANT CI-505) thence into a Garmin 430W and SL30. ILS, VOR works flawlessly...
Brian
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 10-08-2013, 09:49 AM
Default Comant removable elements on VS
This has come up several times I believe. When building the plane I considered one of the "in the wingtip" NAV antennas and called the company direct. The man that answered said their antenna was designed for sport type flying and was not recommended fro IFR. That was the end of its consideration by me. I bought an antenna with removable "legs" and mounted the central element under the vertical stabilizer cap for minimum drag exposure. Typically I unscrew and remove the "legs" for racing but not always (like this past Sunday) because I need a fast getaway and the drag is small. It works very well and I drive two NAV radios (SL-30 and a Terra NAV) through a special splitter.
Bob Axsom
Old 10-08-2013, 10:10 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Brian
If anyone can make it work flawlessly... Decker can!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 06-06-2015, 02:06 PM
ppowers ppowers is offline
Default vor antenna
What do you guys think is a decent nav antenna. I may not even use a nav radio but would like to install an antenna just in case.
