Old 08-28-2006, 10:44 AM
RV_7A RV_7A is offline
Default Site down and Forum SLOOOOO???
Anyone else experiencing very slow performance?
Also vansairforce.net seems down
-Jeff
www.JeffsRV-7A.com
N808TX
Old 08-28-2006, 10:53 AM
13brv3's Avatar
13brv3 13brv3 is offline
I saw the same thing earlier, but it seems OK right at the moment.
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 08-28-2006, 12:03 PM
Davepar's Avatar
Davepar Davepar is offline
It is slow. Posts sometimes failing, etc.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 08-28-2006, 12:19 PM
cjensen's Avatar
cjensen cjensen is offline
Slow for me too...also just got a problem loading page message.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 08-28-2006, 12:41 PM
n468ac's Avatar
n468ac n468ac is offline
Yes, slow for me too.
Seams since the switch over to the new server?
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 08-28-2006, 01:02 PM
praterdj praterdj is offline
I wonder if this happens at the same time Doug skips out of work and sneaks off to 52F? What a life?
Donald Prater
Formerly 52F now Arkansas...Go Hogs!
RV-8 Empennage Underway
N-284DP (Reserved)
Old 08-28-2006, 01:05 PM
Come to think of it this may be due to so many of us sneaking around at work and surfing the site. I know I'm guilty.
Donald Prater
N-284DP (Reserved)
Old 08-28-2006, 02:13 PM
unqualified unfluencer
I'm researching the slowness.
When I'm at the 'day job' access takes longer because our company has several hundred people on the web at one time.
I always start with www.internethealthreport.com to see if the some part of the web is slow. Then I 'Start' 'Run' 'CMD' and enter the following at the command prompt:
tracert www.vansairforce.com
If it takes awhile on those first couple of hops I know it's not the server, but instead something at my day job's network.
Of course, it could be something on the VAF server end, but I try to rule out everything else first. Four times out of five it's not the VAF server but something in between.
Ugh. Technology.
B,
D
PS: I'll email the ISP and see if they have been monkeying with stuff.
Doug Reeves (your host)
Old 08-28-2006, 03:08 PM
Vern's Avatar
Vern Vern is offline
Default Latency Issues
I'm on 10mps fiber with a T1 backup. Often the forums are sluggish with occasional timeouts. The main site is normally responsive. Today has been worse than normal. I monitor the site at least hourly during the workday. (Have to know the condition of my network
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 08-28-2006, 04:01 PM
Default Why it's been slow (good news, though)
Heard back from the ISP. The server that the static site (everything but the forums) is on moved to the new ISP location a couple weeks ago.
The server that the forums are on is still at the old site and is scheduled to be moved this weekend. From my ISP, "Bandwidth has been running pretty high at the old location for the last few days. There isn?t much we can do about it though because Sprint will not fully troubleshoot connections that are moving in a few days."
Good news is after this weekend it should be much faster (and with redundant paths to the web and with redundant backup power). Expect some hiccups and give it a week or so. It'll get faster.
Thanks as always!
b,
d
