Old 09-22-2013, 07:33 PM
s_tones s_tones is offline
Default pipe thread question
I have a Tee (an826-6) that tightens via 3/8" tapered pipe thread into the gascolator.
The upright leg of the Tee must be vertical to mate with fuel pump.
Unfortunately the pipe thread goes from loose to fully tight in an arc of about 90 degrees which does not happen to bring the Tee vertical as needed.
There is no room for an adapter.
Is there any way to deal with this that I am not seeing?
Teflon tape would do it but I do not want to use it for the usual reason (it leaves debris in the threads)
Any comments appreciated.
Steve
Old 09-22-2013, 07:46 PM
g zero g zero is offline
Default Pipe thread
You can chase the thread with a tap to get your tee to index where you need too.
Tom
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 09-22-2013, 08:13 PM
Can you explain how this would be done?
I am guessing you would be widening the female threads somewhat by driving the tap onto the female threads a bit?
Steve
Old 09-23-2013, 07:04 AM
NYTOM NYTOM is offline
Wink Be very careful with Aluminum
Steve you should try another 3/8 " nipple in the gascolator to make sure what tread wasn't cut deep enough. If the second nipple tightens the same as the Tee then the gascolator female port wasn't cut deep enough. If not then the Tee is faulty. Ideally about 2 & 1/2 turns by hand should be able to be made before things start to get tight. If you do need to open it up a bit, make sure you have a nice sharp (new) tap and be sure to use a Aluminum lubricant. Aluminum threads gall very easliy and things can go south very fast. Take it in small steps and totally remove the tap and clean it at every step. Even a very small chip of aluminum stuck in the tap will cause trouble and tear up the threads. Probably the best thing to do would be to practice on a old fitting or drill and tap some news holes in a piece of solid stock to get the feel of it.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 09-23-2013, 07:23 AM
Wayne Gillispie Wayne Gillispie is offline
Like mentioned...Try another fitting with proper sealant/never teflon tape.
http://www.ring-plug-thread-gages.co...NGT-vs-NPT.htm
Ensure you use the correct tap by checking with the manufacturer. Tap if needed after cleaning threads and applying alum cutting lubricant. Clean thoroughly. Reapply sealant and try again. I try to get 4 threads deep on that size fitting.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-23-2013, 08:16 AM
TX7A TX7A is offline
In case you have an Andair gascolator, then you can 'clock' the fitting around without compromising the tapered pipe fitting. Its in the instructions.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 09-23-2013, 08:25 AM
Thanks to all.
It is not so much a matter of depth since i can screw in 5-6 threads at least. Just that it tightens at wrong angle. I have a new Tee on order and will try the fit. If no better may send them both to manufacturer. Maybe they will mate them
Old 09-23-2013, 09:38 AM
Mel's Avatar
Mel Mel is offline
Proper pipe threads should have one full turn after snug for clocking.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-23-2013, 03:16 PM
flion's Avatar
flion flion is offline
At least. Here is a link - http://www.mechanicsupport.com/articleFittingTight.html. There is no way you should be unable to clock any NPT fitting unless you have bottomed out.
EAA Technical Counselor #5357
Old 09-24-2013, 12:41 PM
Default thanks
Thanks to all.
Excellent resource as always!
Steve
