Go Back   VAF Forums > Main > Safety
  #181
Old 10-03-2013, 04:42 PM
Walt's Avatar
Walt Walt is offline
Here's the tool I made for the nuts, hurts to cut up a snap on but it was for a good cause
P/N: XS1618
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-03-2013, 09:56 PM
JonJay's Avatar
JonJay JonJay is offline
Originally Posted by rvmills View Post
Hey JJ...I may have to revoke your man-card over this one buddy . Buying (or making) a tool that you only need once a year (or heck, just once) is one of the simple pleasures of this hobby. Another is when your friends ask if you have one of those rare "umptifratz" tools, and you get to say, "why yes, of course I do!"
Then again, spending the $ on avgas is pretty cool too. I guess we'll have to find a balance of simple pleasures!
Nasty
Fair enough buddy. Ha!
I think Walt gets two man cards for cutting up a perfectly fine snap on, but he is a pro, and see's more than his fair share of nuts!
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-03-2013, 10:52 PM
rvmills's Avatar
rvmills rvmills is offline
All man-cards safe!
Now to cut up a tool (but not a Snap-On)
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 10-03-2013, 10:56 PM
scsmith scsmith is online now
Default Don't forget the other tool!
The other part of the equation is a tool for holding the body of the rod end straight, i.e. perpendicular to the hinge axis. A tube of the right diameter, with a slot of the right width, with a t-handle rod on the other end, would be great.
wouldn't it be nice if someone else did all the measuring, figured out the right size, and sold them?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 10-04-2013, 12:07 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Easily made from PVC pipe fittings. First appeared on RV builders' sites about 16 years ago. Mine is hanging on my shop pegboard. No need to buy one.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 10-04-2013, 12:33 AM
DCat22's Avatar
DCat22 DCat22 is offline
Someone around here does sell them actually...I ended up with one when I bought all my tools from lots here on VAF.
-Rick Greer, VAF #2492
Old 10-04-2013, 06:53 AM
Toobuilder's Avatar
The other part of the equation is a tool for holding the body of the rod end straight, i.e. perpendicular to the hinge axis...
In a pinch, cleco pliers work pretty well too. They grab the head of the rod end without marring the body or touching the ball.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-04-2013, 08:05 AM
RVDan RVDan is offline
I just use a flare nut wrench. They are similar to what you made, but beefier walls to withstand the fact that they are open. No need to damage a fine tool when you can buy just what you want.
Dan
Old 10-04-2013, 08:06 AM
N941WR's Avatar
N941WR N941WR is offline
...wouldn't it be nice if someone else did all the measuring, figured out the right size, and sold them?
Avery's has just what you described.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-04-2013, 10:02 AM
OLDSAM OLDSAM is offline
Default What am I missing?
Other than the cool factor, why not use a plain open end wrench? Many, really many, years ago, when my tool budget was just going from zero to minimal, the first wrenches I bought were combination type, just because sometimes fuel lines and rod ends and similar stuff would not allow the box end to fit.
OldSam
RV7A, Empennage, Wings & Tanks complete
Fuse under way
