Old 09-17-2013, 04:05 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default Pro-Seal vs. Gasket
I'm just now getting around the Vans Service Bulletin re: fuel tank anti-rotation bracket (my tanks were built in 2000) and have seen some builders talk about sealing the access panel with Pro-Seal instead of replacing the gasket.
I'd rather just replace the gasket because it seems to me that Pro-Sealing the access panel would just make it even more difficult to open it up later if needed, but if there's a good reason to take the Pro-Seal route, I'd like to know why.
Can anyone shed light on this?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 09-17-2013, 04:07 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Nope
Proseal not a problem. Cork gaskets seep over short time, sealing my RV1 wings and fuel sender with proseal as we speak.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 09-17-2013, 04:31 PM
DaveO DaveO is offline
Jerry,
Prosealing the tank will cause you problems in the future. That is if you wish to remove the object you are securing. Remember how good of a job proseal does to the tanks to seal the corners and seams? Does that proseal ever come off?
That is what is suppose to do. Stay stuck! But to remove proseal? not me. There are other very good sealants that you can use on the tank, and not leak.
Think about it. In fact if you do a search about it on this forum you will find the issue tried already.
Dave
Old 09-17-2013, 04:37 PM
YellowJacket RV9 YellowJacket RV9 is offline
I read somewhere that there is a less adhesive version of pro seal that some has used for the access plate, that will seal but be easier to remove. Maybe somebody had more info on that. I just used the regular stuff, and hopefully never have to remove it, but it will be doable if needed.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 09-17-2013, 04:57 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I had to remove an access plate that had been pro-sealed in place.
Took about ten minutes. It's a lot easier than some think, and I hate fuel seeps/leaks....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-17-2013, 05:13 PM
RV6_flyer's Avatar
Originally Posted by Davoakes@att.net View Post
Jerry,
--- snip ---
Dave
I disagree.
No issue removing a cover installed with ProSeal IF you know how to do it.
I have taken the Rear Close out off of both tanks on an RV-4 and was able to reuse the Rear Close out. I have had both access covers off my RV-6 tanks twice since they were built. Once before I flew when I thought I did not tighten the pickup then again to perform the Service Bulletin on the fuel pickups.
To remove any cover that has been installed with ProSeal, use a Putty Knife with the blade as Parallel to the tank and cover hit with a hammer. Use the putty knife as a KNIFE to cut the seal. DO NOT Pry the cover off with anything.
I have only seen one gasket that had not leaked. Over time, it may have leaked. My RV has been flying 16-years and over 2,740 hours. I may not have seen ALL RV Problems, but I have seen my share.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-17-2013, 05:31 PM
Sounds like Pro-Seal is the answer....
www.marksrv8.com
Old 09-17-2013, 05:45 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Van's actually sells pro-seal remover. Works Great!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 09-18-2013, 05:01 PM
I stand corrected
dave
Old 09-19-2013, 07:14 AM
dhammer's Avatar
dhammer dhammer is offline
Chris
Try PR-1428 Low Adhesion Access Door Sealant
