Old 09-16-2013, 11:19 PM
acroflyrgirl acroflyrgirl is offline
Default Rough running....diagnosis help
MX quiz.
A few weeks ago I did a runup and had a bad spark plug, or so I thought. Mag drop low on one mag, EGT hot. Taxi back, remove #3 bottom plug due to the EGT tip. Put in a new plug and the plane flew great....for the next 13 hours.
Last weekend, flew a few flights, all was well. 2nd flight on Sat. The engine began running rough. EGT's & CHT's normal but rough between about 2000 and 2550 RPM, smooth everywhere else. Mag check good at all power settings.
Took all the plugs out and #3 bottom was a bit wet with oil. Cleaned all plugs, installed and the run up was fine. Took off at full power, 2600 RPM all is good, then as I start pulling the prop back it did the rough running thing again. Smooth at 2600 & above, but rough still between 2550 down to 2000. Smooth as silk at 1900.
I did a cold compression check. All cylinders were 70 to 76, and I removed the oil filler stick/cap and heard a little bit of air.....on each cylinder. At first I thought ahh hah, but on each cylinder, with good compression. I guess that is normal?
The local IA, who is mostly a Continental 520 guy, asked me about my mags.
I have Slick mags with 970 hrs on them. I had some trouble with them earlier this summer and had the internal timing adjusted, but did not overhaul (yellow tag) both mags.
This local MX guy thinks it's a mag issue. Does that sound right in your opinion? I'm assuming the good compression eliminates a valve or a ring problem.
Old 09-17-2013, 01:14 AM
PCHunt PCHunt is offline
Hi Cathy!
Carbureted or injected? 970 hours on Slick mags is a lot of time. There is a 500-hour AD on Slick mags.
The fact that your engine is rough at some RPM's and not at other RPM's might point to an injection problem if you are injected.
If carbureted, or for that matter, even if injected, might check for intake leaks.
"Grabbing at straws"
Pete
PS: How rough? What kinda rough? Have you done an airborne mag check at cruise power? Do you have an engine monitor that might provide data? Is the carb loose?
Lotsa Questions!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 09-17-2013, 02:06 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Without a data file to study, here are a few things you should check first.
1. Plugs, gaps are 0.016-0.018" for massive electode plugs. The resistance needs to be below 5000 ohms too.
2. Carefully check your inlet gaskets and intake tube couplings. Do a GAMI Lean test both high and low altitude to detect leaks.
3. Get your mags overhauled and if the plugs have been there all this time the coils might be stressed. Make sure they get put back on and timed correctly, and you would be horrified how many times this is wrong.
4. If fuel injected the fuel pressure might be an issue if it is hot and the fuel flow is dropped back, by any chance are you running mogas? I doubt the injectors are dirty. What could be a problem is a build up of gum/sludge on the rubber diaphragm in the fuel control unit, and this can do funny things to the fuel flow. Usually from over priming or priming with hot starts.
5. you could have a good look at the EMS data file to see if anything is trending away from normal.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 09-17-2013, 11:06 AM
AZtailwind's Avatar
AZtailwind AZtailwind is offline
Originally Posted by acroflyrgirl View Post
MX quiz.
Cathy, I have a Slick Mag sitting here from the P-Mag conversion- It was overhauled about 400 hours ago if you need something loaned for diagnostics
Brad Ransom
http://www.westcoastravens.com
RV-6A 180HP-acquired
RV-4 180HP-acquired
Old 09-17-2013, 02:29 PM
Default Bits
It is carbureted, I did do a full power mag check with normal results.
I am sending the mags out today for overhaul. That will eliminate one question at least.
I checked the induction, all snug. I'll know in a few days if the mags fix everything or I have to keep digging.
Old 09-17-2013, 06:09 PM
ifixf15's Avatar
ifixf15 ifixf15 is offline
Default Call Mike
Cathy, before spending any REAL cash you may want to upload your Engine Monitor data to the SavvyAnalysis.com and e-mail a list of your symptoms to Mike Busch. Also, if you are sending your mags out, you may want to ask for an IRAN (Inspect and Repair As Necessary) instead of using the O word. With 970 hours, an Overhaul may be a bit of overkill.
Tom
Tom
MSgt, USAF, Ret
N318RV Reserved
Gathering tools
Dues paid
There are 10 kinds of people in the world, those who understand Binary and those who don't.
Old 09-22-2013, 02:09 PM
Default Troubleshooting
So, can I get info off my Dynon 180 that could point in the right direction for diagnostics?
Old 09-22-2013, 06:14 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Depends on D180 settings
Cathy,
If your D180 is set to record the data and the sampling rate is fine enough then you could download engine data in an excel format for review.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
