Old 09-15-2013, 08:10 PM
AK-Models AK-Models is offline
Default O-360 cowl v. IO-360 cowl?
Ready to buy a finish kit (from someone). Planing on installing IO-360 however, finish kit lists 7A cowl kit O-360. Are they compatible with IO-360 or not?
Please help if you know.
RV-7A Standard kit
Empenage - Finished
Wings - Finished
Fuselage - almost done
Panel and engine done.
On to fiberglass.
VAF Donation 2020
Old 09-15-2013, 09:05 PM
sjhurlbut sjhurlbut is offline
Default Depends
The cowling is likely set up for vertical induction carb. If you're using vertical induction fuel injection, you'll be fine. However if your planning on using horizontal induction, then you want the cowling with no chin scoop.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 09-16-2013, 06:32 AM
Walt's Avatar
Walt Walt is offline
Van's IO360 (smooth) cowl is used with all angle valve engines and horizontal induction systems.
Van's O360 cowl (snorkel) may be used on all parallel valve engines with vertical induction (FI or carb).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-16-2013, 08:26 AM
So I would have to make some modifications to the engine I want to buy from VAN's:
XIO-360-M1B 180 horisontal cs
Unless I can specify vertical induction v. horizontal... when ordering with VAN's
RV-7A Standard kit
Empenage - Finished
Wings - Finished
On to fiberglass.
VAF Donation 2020
