Old 09-15-2013, 06:24 PM
John Courte John Courte is offline
Default Slick Mag Harness Screws - part number/spec
Does anyone have a part number or spec for the screws that hold the distributor cap onto the back of a Slick 4300 magneto?
In the clusterf-- er, process that was yesterday's magneto timing session, one of my screws fell out, and went missing, possibly kicked by yours truly or one of the other hangar occupants.
The problem with an asphalt floor is that you can't hear things hit it. This is how I locate most of the various things I drop, or used to before I moved to the airport. Small, non-shiny things falling on it might as well be sinking into the black depths of a Michigan lake.
Thanks in advance,
-John
RV-7 N313TD
SOLD 7/2/2020
Old 09-15-2013, 06:42 PM
Never mind. Part # M1553, available at ACS. Searching for "slick magneto harness screw" doesn't turn up anything, but searching for the part number does.
RV-7 N313TD
SOLD 7/2/2020
