Strobe Wiring
I was planning to wire everything from each wing to sealed connectors at the wing root, so I can just "plug and play" when I mount the wings for good.
My question is about the shielded three conductor cable for the Whelen strobes. What is the right way to handle the shield? Is it correct to allocate 4 connector pins, three for the power and trigger (red,black,yellow) and one for the shield?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
