09-12-2013, 12:50 PM
Static line access
Afternoon!
Could some one help me with a decision please. I was plumbing the static line to the various gages in panel. Basic set up is: Static line to a Safe air manifold, then branch off to the Alt, the ASI, the VSI, and the encoder. All from the manifold. Its a simple and clean way to do it but now I realize I dont know where the test equipment is to be tied in during the biennial transponder check.
Sooo... Should I add a t-fitting before the manifold and pug the unused port to tie in there or should I tee in AFTER the manifold and do same thing? Does it matter?
What is done when they tie in? I assume they pressurize and test for leaks maybe?
Why is transponder turned on during test? Do they pressurize to say 1000 feet AGL and then check transponder signal or something?
Basicly need a transponder/static sys check for dummies explanation and how I can make my system easily accesable later.
Its VFR and encoder is simple ameriking.
Thanks guys!
Bill
09-12-2013, 05:27 PM
When I've been there while my 170 was being done, they use the static port on the outside of the airplane. No breaking in to the system; no need to provide a test port.
Transponder and altimeter get tested to 20000 ft (I think in 2000 ft increments??).
RV-7 TU 904KM (reserved)
Construction Log
09-12-2013, 05:31 PM
Senior Curmudgeon
I just had my xpnder check this week, and it was done with only a electronic gadget that sat on a tripod next to the plane. No actual physical contact with the plane at all.
The tech said that for a VAF certification, there was no need to check the static or pitot system.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
09-12-2013, 05:35 PM
How can you gauge the accuracy of your encoder without applying the various altitudes to the static system???
Construction Log
09-12-2013, 05:41 PM
Rather than doing a bunch of copy and pasting, check my FAQ page on my website, I think it should answer all your questions, if not please let me know.
http://www.expaircraft.com/faq.htm
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
09-12-2013, 05:45 PM
Senior Curmudgeon
Set the EFIS to 29.92". The encoder is in the EFIS. This may not work for steam panels with separate encoders??
Mike Starkey
VAF 909
Rv-10, N210LM.
09-12-2013, 05:48 PM
Still, you've got to change the pressure physically applied to the static system somehow, no matter where the encoder is.
Construction Log
09-12-2013, 05:51 PM
Senior Curmudgeon
Miles, I have no idea what is needed, I only followed the instructions the guy with the license gave me.
Mike Starkey
VAF 909
Rv-10, N210LM.
09-12-2013, 05:57 PM
An easily accessible test port on RV's can be a handy thing, sometimes my equipment has trouble sealing on the 'rivet' static port.
09-12-2013, 05:59 PM
You can do a transponder-only check (does it receive interrogations and reply properly) without connecting to the airplane, but you HAVE to connect to the static system to check encoder accuracy.
Construction Log
