Old 09-12-2013, 11:47 AM
Builder Bill Builder Bill is offline
Default Whats a good way to store 5606?
You open the qt. can, you use a fraction of that to bleed brakes. Want to keep the remainder clean & dry.
Mason Jar?
Old 09-12-2013, 11:52 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
A metal can with a screw-on cap. Like an old can that used to contain solvents, paint thinner, mineral spirits, B-12 Chemtool, automotive brake fluid or power steering fluid, hydraulic fluid, etc, etc.... just make sure to clean all the former contents out completely and re-label it appropriately.
Neal Howard
Airplaneless once again...
Old 09-12-2013, 12:31 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Plastic pop bottle
I cleaned out a pop bottle, made sure it was dry, and filled it up!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 09-12-2013, 12:52 PM
rzbill's Avatar
rzbill rzbill is offline
Bobby,
Pop bottles are traditionally made from Polyethylene Terephthalate (PET).
It is not a good moisture or oxygen barrier so it is not a good long term storage place for hygroscopic brake fluid.
If you must use plastic, get a ketsup bottle (hazy translucent) with a 7 or a 5 SPI recycle code. It should be Polypropylene (good moisture barrier) on the outside and possibly Ethylene Vinyl Alcohol (great oxygen barrier) in the core layer.
I don't remember what the original container was for my brake fluid. If it was plastic, it has to be a moisture barrier construction of some sort. There are multiple ways to do it but the consumer has little method to know how the container is made.
If one wants to use a different container in order to reduce the "headspace" vacated by the used fluid, then metal or glass is the trick.
Bill Pendergrass
ME/AE '82
Old 09-12-2013, 01:48 PM
bkilby's Avatar
bkilby bkilby is offline
Default Plastic bottle from ACS
This is what it comes in from Aircraft Spruce..
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 09-12-2013, 02:01 PM
Is plastic a problem for 5606?
I've herd that DOT-3 automotive is hygroscopic, but it retails in plastic.
Old 09-12-2013, 02:11 PM
rzbill's Avatar
Is plastic a problem for 5606?? Good grief man. Plastic is not plastic. There are just as many variations in plastic chemistry as in metals. Do you make your RV out of 100% steel?
As I said, or meant to say, you can package hygroscopic stuff in plastic.
However, that is done by the manufacturer and the combination is controlled so IT WORKS.
Most laymen think all plastic is the same. IT IS NOT. If you want to put a hygroscopic material into a plastic package and expect it to survive, you need to know something about the package. That is not easy. The SPI coding on the bottom does not tell the whole story, only a part of it and only if the manufacturer is not stretching or breaking the rules for marketing reasons.
One of the main ways to package many chemicals in "plastic" is to blowmold a bottle using high density polyethylene (HDPE) but to use flourine (very dangerous) instead of air to inflate the bottle. The flourine reacts with the hot HDPE and creates a poly tetra flouro ethylene (PTFE or teflon) inner skin on the bottle which is an EXCELLENT barrier. Done. Put in whatever chemical du jour you would like.
There are multple ways to skin the cat.
Bill Pendergrass
ME/AE '82
Old 09-12-2013, 02:22 PM
Ron B. Ron B. is offline
Where as I only use small amounts at a time, I just pock a couple small hole in the can. One for the pouring and one for the vent. Then I use small PK screw (I think that is what they are called) with a plastic flat washer. I just screw two into the holes.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 09-12-2013, 03:48 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default zip lock
So if my partially used can has sat open but in a zip lock bag for the last year, is it now trash?
Never thought of the storage rewuirement.
cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 09-12-2013, 05:20 PM
Neal@F14's Avatar
It's just hydraulic oil. It stays exposed to atmospheric oxygen and water vapor all the time when it's in our airplanes with vented reservoir caps, and still lasts for years and years that way. The important thing is to keep it in a container that will keep it clean, keep any dirt out, and help you avoid spillage while in storage. I chose a metal container with a screw top lid because such cans are readily available around our airport, and they don't break if you drop it
Neal Howard
