Old 09-12-2013, 09:26 AM
BDFLYER BDFLYER is offline
Question Aeroquip 666 Fittings + AN832 = Corrosion Risk?
Quick question for the experts amongst us:
I am moving from Aeroquip 303 with standard aluminum AN fittings to Areoquip 666 (mostly to address the 303 degradation risk when using MOGAS with up to 15% alcohol content, especially on the returns).
Unfortunately, 666 uses stainless (CRES) fittings, though mechanically compatible, I have some concerns on having the 666's AN stainless fittings connected to AN aluminum fittings.
Any sense from the crowd on if my perceived risks around possible corrosion is well founded?
Last edited by BDFLYER : 09-12-2013 at 09:27 AM. Reason: Correction of 333 to 303 on hose type
Old 09-12-2013, 10:03 AM
rzbill's Avatar
rzbill rzbill is offline
Where do you have aluminum fuel fittings forward of the firewall?
Mechanical fuel pump is steel. There are only a couple more. There is one train of thought that says to use steel only. I do. Change them out. Solves the aluminum/SS galling question and removes any issue with aluminum fittings forward of the firewall
Bill Pendergrass
ME/AE '82
Old 09-12-2013, 11:44 AM
We really prefer steel fittings FWF, although aluminum has been used for years.
Ridgeland, SC
Old 09-28-2013, 05:40 PM
So, the use here is not FWF. If we set aside the discussion on FWF or not, any thoughts on the core question?
Old 09-29-2013, 07:57 AM
Airframe guys might chime in, but we havent seen any issues, even in planes being 20 years old.
Tom
Ridgeland, SC
Old 09-29-2013, 11:54 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I'm not aware of any corrosion issues with anodized aluminum fittings and stainless or any other types. Anodized aluminum is pretty inert/ impervious to most aviation materials.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 10-01-2013, 07:52 PM
Excellent! Thanks!
