Old 09-05-2013, 09:52 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default Tip: Sikaflex Primer Masking Test
Just wanted to share my results with the group in hopes it will save others some time.
I am getting ready to glue my canopy and I wanted to see tape would perform best with the sika primer.
Here is a list of the tapes that I was able to find locally with realitivaly little effort:
3M Blue Painters Tape (Home Depot)
Frog Tape (Home Depot)
Rust-oleum Professional tape (From auto zone) how the primer would perform
Old Cheap Electrical Tape I had in my tool box
Scotch/3M Professional Grade Super 88 Electrical Tape (Home Depot)
Scotch/3M Professional Grade 35 Yelloy Electrical Tape (Home Depot)
The Results:
All the masking tape performed poorly, the Frog Tape was the worst. The Scotch/3M tape did the best, and it performed best when you let the primer dry and the remove pulling toward the primed side. I likes the yellow tape best as it offered better visibility with the contrast.
I would have liked to try Fine Line tape by 3M but was unable to find a source locally.
Hope this helps other.
BTW, the canopy pieces love the 100 degree AZ temps, I had to work very hard to get the scraps to crack/fail.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 09-05-2013, 11:27 PM
Black PVC electrical tape works as well as 3M FineLine for
the application of the sika primer.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 09-06-2013, 04:05 AM
mike newall's Avatar
mike newall mike newall is offline
Just done our 8 canopy.
As Lorne says - 3M fine line tape, then we backed up with Home Despot blue tape.
Gives a really good, crisp line. Used it on our 7 a few years ago.
Putting the fillets on in an hour !
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 09-06-2013, 05:53 AM
krw5927 krw5927 is offline
I'll second that frog tape is a really poor choice for this application. Unfortunately this information comes about 3 weeks too late for me, and I'd already used frog tape. I would've been better off painting my primer on by hand. Ugh...
Kurt W.
RV9A
FLYING!!!
Old 09-06-2013, 07:45 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default 3M Fine Line
3M is the only tape you should be using directly on your canopy for this purpose. I know a lot of people have used electrical tape but the Fine Line adhesive is designed to withstand the various chemicals used in the painting process. This is not a place you want a problem. It is much more than just getting a good mask line, it is avoiding a potential chemical reaction.
I use Fine Line for the initial line and then back it up 3M vinyl tape.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
