Just like aluminum, it needs to be prepped and primed accordingly. I sandblasted mine and coated it with DuPont VariPrime.
Essentially, it needs to be cleaned, profiled, cleaned again. If you don't have a sandblaster, scuff it with 180 grit sandpaper. Once that is done, most any primer suitable for steel is fine.
CJ
