Old 09-03-2013, 05:30 PM
patterson patterson is offline
Default Airflow Perfomance FI - need airbox
Does anyone on the list do a modified airbox for an O-320 converted from carb to FI using the AP150 kit?. I'd like to install this upgrade and hope to avoid having to reshape and repaint the cowling to install this on my RV-4
Ron in California
n8zd@yahoo.com
510-421-2316
Old 09-03-2013, 08:57 PM
bruceh's Avatar
bruceh bruceh is offline
I'm not sure what exactly you are asking here. The filtered airbox from Van's can be used with either FI or carb. The carb installation has an extra opening for carb heat. FI doesn't need that, so it can be closed permanently. The carb installation also has a small bit of the airfilter cut out to fit the carb. You should be able to leave that alone. I've got the AFP set up on my O-320 and have lots of pictures here. Even if you have to put on a new airbox, it should be able to be fitted up to your cowling without having to affect anything externally.
Bruce Hill
2020 VAF donator
Old 09-04-2013, 01:10 PM
Default Good Pictures
Thanks for the pictures Bruce.
Ron
