Old 09-01-2013, 07:12 AM
mikeasselin mikeasselin is offline
Default Tip: Removing tape from tie wrap anchors
Playing around in the shop this morning reading posts on securing wire. It seems attaching the tie wrap anchors with proseal or jb weld works but first need to remove the two way tape on the back of the anchor.
While doing a trial on the effect of heat on the two way tape (using a heat gun) I quickly found that the adhesive let go at minimal increased heat. I used a heat gun to heat up the anchor a bit and found that it removes the two way tape on the anchors in seconds. I was dreading having to cut off the tape or use solvent.
Now on to the task at hand - securing the wiring!
Mike Asselin
RV 7A - finish kit,
Arnprior, Ontario
Canada
Old 09-01-2013, 08:12 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Thanks for the great tip!
I have been struggling with scraping these suckers. This will help a ton and alleviate the need to drill holes and use Adel clamps in inconvenient places.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 09-01-2013, 08:24 AM
TX7A TX7A is offline
I used Goo Gone. It takes it right off. Got at Lowes.
Then wiped with lacquer thinner. Then scuffed with 80 grit, then wipe again with lacquer thinner.
I've had good success with JB Weld & Goop. I didn't use this app in any heated areas.
I also bought bases without any adhesive from Mouser. Some with & some without holes for rivet or screw attachment.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 09-01-2013, 09:49 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Soak them in MEK in a jar overnight. The two-sided foam tape falls off easily the next day.
I attached mine using Automotive Goop (available at the auto parts store). It never dries hard, and is very strong.
Another bit of advice is when you mount them, put a scap nylon ziptie through the hole you intend to use. Once dry, it can be a pain to get a ziptie through. If one is already in place, you can work it back and forth to remove any adhesive that had gotton too far up into the nylon cable mount which could interfere with the tie going through the holes.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 09-01-2013, 10:02 AM
Default Try the heat gun
Give the heat gun a try - no messy brain eating chemicals!
Mike Asselin
RV 7A - finish kit,
Arnprior, Ontario
Canada
Old 09-01-2013, 12:23 PM
daviid daviid is offline
or buy them without adhesive
http://www.panduit.com/wcs/Satellite...ame=PG_Wrapper
Old 09-01-2013, 04:14 PM
BillL BillL is offline
I put a bunch in lighter fluid (naphtha) and when I pluck them out, clean residual with paper towel. Windshield urethane becomes the new mount.
Bill
RV-7
Lord Kelvin:
