Go Back   VAF Forums > Model Specific > RV-9/9A
Old 08-31-2013, 08:28 PM
guccidude1 guccidude1 is offline
Default Can't find the danged part number
Guys: I managed to boorger up the socket head shouldered bolt that holds the brake mounting flange to the gear leg on my RV-9A. Who would have thought that is has course threads, well the threads are not course anymore, they are non-existant. Does anyone know what the part number is, I can't find it anywere on the digtal drawings or Van's "the list". Thanks, Dan
Old 09-02-2013, 07:18 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Is it described on DWG C2, VIEW F-F? Looks like a 5/16-20 X 1 1/2 "screw". I will look at mine tomorrow and see what is actually there.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 09-02-2013, 07:22 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Angry Bolt thru leg
Do you mean the single bolt through the gear leg; left side of drawing C2?
That is 5/16" (20 threads per inch) x 1-1/2" long. Found in Van's catalog under "screws" ...naturally :-)
SCREW 5/16-20X1 1/2 $2.00 ea
Good Luck!
Alan
RV-9A N984AW
Old 09-02-2013, 07:32 PM
Thanks guys: I found the C2 drawing and the bolt (screw) description and was looking for a part number to order. I'll call tomorrow and get a couple with course thread nylock nut. Thanks again, Dan
