Solid Flange crankshaft ..Q
Motor is IO-360, 200 hp. aircraft is a Zlin. Plan to use MT prop.
Is there any good reason to keep my crank with the lightning holes..?
Before I spend the money for the solid flange, I want to make sure it is the right thing to do.
I will be doing aerobatics. Not competion, but .........
I expect I know what's coming, so let me have it.. I just didn't want to spend without covering everything. And you RV'ers have the best intel on these things.
Thanks, Kem
