Old 08-31-2013, 05:34 AM
drmax drmax is offline
Default main wheel torque?
Is there a torque spec on mlg wheel? I'm doing inspection and redoing brakes. I have the construction manual and didn't find anything on this.
As far as the nose, I'm sending wheel assy to antisplat and having the bearing mod accomplished.
Old 09-02-2013, 07:19 AM
Jesse's Avatar
Jesse Jesse is offline
Are you talking about the axle nut or the brake caliper bolts? On the axle but, you should count the turns to take it off and put it back on the same. On the brake calipers, I use the standard AN-7 bolt torque (around 70 in/lbs IIRC).
Jesse Saint
Old 09-02-2013, 07:27 AM
Mel's Avatar
Mel Mel is offline
I think you mean AN-4 bolts. AN-7 would be pretty large for brake calipers.
50-70 in.lbs.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-02-2013, 07:28 AM
Walt's Avatar
Walt Walt is offline
Axle nut: (from Timken Bearings)
To adjust the setting of this bearing:
Step 1: Tighten the nut while turning the hub. When there is
a slight bind on the bearing, the parts are seated correctly.
Step 2: Back the nut off 1/6 to 1/4 of a turn or sufficiently to
allow .001” to .007“ end play.
Cleveland brake caliper specs: 65-75 in/lbs dry.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-02-2013, 07:37 AM
allow .001? to .007? end play.
axle...thx gents. may just ship all my wheels off to get the bearing mod accomplished. uncertain at this point. while i have you...does the wheel have to come off to get at the brake pads? matco assy. thx
Old 09-02-2013, 07:48 AM
Mel's Avatar
Mel Mel is offline
No. When you remove the 2 AN-4 bolts the caliper will split and you can remove the pads without removing the wheel.
