08-28-2013, 10:21 AM
Conduit exits
I have been running through old posts and looking at build sites and I haven't been able to find any pictures. For guys who used some sort of solid smooth wall tube for conduit, how are guys exiting wire bundles mid wing when the conduit continues to the tip? Did you end and begin the conduit? Did you put a hole in it? Pictures or explanations would be greatly appreciated.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
08-28-2013, 10:39 AM
Senior Curmudgeon
Bellmouth fitting
Standard parts for home electrical, made with a smooth radius for the wires to exit from. Also they hold the conduit in place.
Aviation isle at Home Depot Lowes, or other electrical supply store.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
08-28-2013, 11:02 AM
I used a 3/4” OD x 5/8” ID clear vinyl tubing from the root to the Pitot / Autopilot Servo area. It can be found in the very back of the Home Depot Aviation supply; Manufacturer is Watts, P/N SVLK10 $7 for 10 ft. It can be seen in picture coming from the left (inboard) side. The aluminum tubing is thin walled 3/4" OD tubing found at an actual Aviation supply store. I wanted to run the aluminum tubing all the way through, but you will find after you drill out the conduit holes to 3/4” in the ribs that most of the holes don’t line up very well once final size, especially in the inboard ribs for the wing walk area requiring flexible tubing. The Clear Vinyl tubing pulled through my completely assembled right wing without any problems from root to tip. I made a 1/2” x 1” cut easily in the tubing for the A/P servo wires. When I bought the wings, they had the black flexible convoluted tubing but it is a pain to run wire bundles though so I ripped it out and replaced it with the Vinyl tubing.
If you are 90% efficient, and your buddy who checks the 10% you missed is also 90% efficient, together you're 99% efficient.
RV-7A - empennage done minus glass
wings nearing completion
Reason: fixed pic
08-28-2013, 04:08 PM
I used clear T8 fluorescent lamp protectors for mine. 4' is perfect for the outboard section, 8' cut down for the inboard section. I ran the each one from the respective wing end to the aileron bellcrank bay, so there's about a rib space between the ends there.
Dale
Omaha, NE
Previous RV-7 project (sold)
08-28-2013, 09:27 PM
Thanks guys. Keep the ideas coming.
Dale,
I was in Home Dumpo the other day buying a ballast for a fluorescent fixture when I saw that stuff. I was intrigued by it due to the extreme light weight. I wondered if the size for T5 tubes might be better. I haven't totally decided against it but all I can find around here are the 4' sections and I am not all that interested in bonding two of them together. Did you run it through the lightning holes and secure it with cushion clamps or did you drill the ribs? If you drilled the ribs how did you protect the tube from vibration?
Mike,
what did you use for the actual conduit? Honest to goodness electrical conduit?
Randle,
I can't make out how you protected the tubbing. It looks like a grommet on the clear and a cushion clamp on the ally. Is that right?
Sam
Fuselage underway
N18451 reserved
08-28-2013, 09:56 PM
Senior Curmudgeon
Originally Posted by xblueh2o
Mike,
Yep. Blue flexible stuff they call "Smurf" tube.
Mike Starkey
VAF 909
Rv-10, N210LM.
08-28-2013, 10:40 PM
Sam,
Here's some detail on how I did it: http://www.botkin.org/RV-build/?p=782. I made the brackets out of some stock I had handy and just pop riveted them in place. The tubing is secured with zip ties and RTV. Though the build log doesn't say it clearly, I put a good little glob of silicone between each bracket and the tube before cinching down the zip ties. If I'd seen T5 tube shields I'd have used those -- the T8 is a little bigger than needed! At least I'll be able to run coax through it if I need to.
My thinking is I'll run all the wires, put a few zip-ties or lacing cord in place to keep the wires secured, and see if/where I need to put adel clamps in there to keep wires from flopping around.
Dale
Omaha, NE
