Old 08-27-2013, 03:25 PM
hammer408 hammer408 is offline
Question Dual Impluse Mags
Is there an advantage in running dual impluse mags vs 1 impluse and 1 non-impulse. I'm about ready to order my engine and all mnufacturer's offer this as an option.
thanks
Old 08-27-2013, 03:31 PM
N661DJ N661DJ is offline
Easier starting, 2 impulse couplings will usually help starting.
Old 08-27-2013, 05:10 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
in a production airplane, a dual impulse mag set up was called a Bush kit.
For the exact reason the previous poster mentioned. In 8+ years that I
had my -6, It operated fine with only one impulse mag. Something to consider
if you plan to eventually add a P-mag and or other electronic
ignition with a hall effect sensor, you are better off with one impulse
coupler mag. That makes a p-mag, a drop in replacement, for the non-impulse coupling mag.
If you have two impulse couplers, you must remove the spacer on the engine that accomodates
the extra length for the impulse coupler, and replace the studs with shorter ones.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 08-27-2013, 06:02 PM
cjbouldin cjbouldin is offline
....and buy two mag gears at $200 plus each. The impulse coupled gear won't work with P-Mags.
Chris
RV8/A
5NC5 The Duchy
