Old 08-26-2013, 04:50 PM
turbo's Avatar
turbo turbo is offline
Default another odyssey battery dies
this battery was 5 months old and just died one day. glad i was at home base. the store replaced it for me and i now have 19 months left on the warranty. glad i bought it from a chain store. this time i will keep the purchase info in the plane. it took 3 tries to get the correct store in florida to confirm the purchase.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 08-26-2013, 08:10 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Another?
Have you had more than one go bad? I have been using a PC680 for almost 4 years with no problems. I even left the master on and drained it completely down once and it charged back up. I don't read everything in this forum but I don't remember other people having problems either. I will probably change it out on the 4 year anniversary just as a preventive maintenance measure.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 08-26-2013, 10:15 PM
9GT's Avatar
9GT 9GT is offline
Ed, I would be interested in knowing if you used one of those maintenance or trickle charger's of some sort.
David C.
Howell, MI
Old 08-26-2013, 11:06 PM
N427EF N427EF is offline
How about one of these?
These are much less expensive choices and do a fine job on my 540.
I've had 2 of these in my RV-8 for 8 years changed out once just for good measure and the same 2 on my RV-10 2 years now and going strong.
These are locally available and don't seem to have a downside. Everyone flying experimentals on our airport is using these.
http://www.apexbattery.com/mk-batter...k-battery.html
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 08-26-2013, 11:36 PM
gasman gasman is offline
Eight years on my PC680 also. It is in a full metal holder with no holes cut out. Never on a trickle charger. PP alternator. I load test it once a year.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 08-27-2013, 07:35 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
9 years on mine before I took it out still working fine and put it in my winter car. We'll see how much longer it goes there.
Clearly, despite all the care and testing that goes into these batteries (see that YouTube vid Dan posted), some duds sneak though the process.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 08-27-2013, 08:39 AM
John Courte John Courte is offline
Not on an RV, but I just replaced an Odyssey battery in my Buell X1.
Okay, maybe it didn't like riding around in that vibration-intense environment almost completely on its side.
RV-7 N313TD
SOLD 7/2/2020
Old 08-28-2013, 11:06 AM
dmeloche dmeloche is offline
6 years on mine, replaced it for no reason other than age, left it on a garage floor for 2 years where it lost all voltage. When the battery on my lawn tractor died I thought what the heck? I put a charger on it for a few days, it came back to life and is now living a second life on the tractor. What a great product!
Doug
RV6
Old 08-28-2013, 11:25 AM
ColoRv's Avatar
ColoRv ColoRv is offline
Odyssey batteries are dry cell AGM types. It amazes me how often I see people using chargers on them that are not designed for AGM batteries. Left on a trickle charger not designed for this type of battery, an AGM is destroyed long before its time. They're heavily used in RV's (the drive on road types) with wonderful results provided they are not tortured with the wrong chargers.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 08-28-2013, 11:35 AM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default AGM...
now I know what destroyed mine after leaving the Master on, wrong type charger, thanks, good to know.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
