Old 08-24-2006, 01:17 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Default Superior XP320 (finally)
I just received a brochure in the mail today announcing the range of Superior's XP offerings.
They list
XP320
XP360
XP361
XP400.
The 320 is available with three compression ratios standard, giving 150, 160 or 165 HP.
-Mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Last edited by mlw450802 : 08-24-2006 at 03:55 PM. Reason: added photos of brochure
Old 08-24-2006, 02:01 PM
kcameron kcameron is offline
It's a shame they don't keep their (otherwise excellent) website up to date.
XP361???
I guess they needed a product to fill the gap between the xp-360 and xp-400.
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying
IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
Old 08-28-2006, 08:41 AM
osxuser's Avatar
osxuser osxuser is offline
I'm guessing the 361 is probably an angle valve? They used the same picture under all the engines, so that doesn't help...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-28-2006, 04:22 PM
Superior-Sales Superior-Sales is offline
Default xp-320
Hi all, the simple explanation for the XP-361 is it's the easy way to differentiate the XP-360 180 hp parallel valve engine from the 200 hp angle valve engine as one of you so deftly noted! Web site will be updated shortly as well! Both engines are actually 361 CI.
Knick Curtis
Superior
Old 09-03-2006, 03:33 PM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Build-It-Yourself option?
Just curious to know if they also plan to offer Engine Build School for the -320 as they do for the -360.
I'd love to build my own engine, even if currently all of this is a dream.
Daniel Mouly
LFCD
RV-9A (Reading Preview Plans, and dreaming)
<Oops>Sorry for the stupid question, I just found the answer (a YES) reading another thread called XP-360
</Oops>
Old 09-04-2006, 10:07 AM
osxuser's Avatar
I want to be able to order a kit-engine and just have the parts show up at my door... I don't need assembly school
RV7 emp built
Old 09-04-2006, 10:38 AM
Radomir's Avatar
Radomir Radomir is offline
Stephen, call A.E.R.O. -- they'll sell you an ECI 360 kit.. at a very reasonable price (better than seen on this forum)... no accessories, of course.
Radomir
RV-7A sold
Old 09-04-2006, 11:55 AM
David Johnson David Johnson is offline
It is a wise person indeed who will take care consider more than price in these things. There is a lot of time at 12,000' above the Bitterroot Wilderness to think about the quality of one's powerplant vs. the price paid, as I did recently
I think Superior makes a better kit for a handful of reasons that may or may not be of interest to you. They've made some key improvements to the Lycoming design that you won't get from ECI. The beefed up block is worth the additional cost alone (to me at least), after seeing my friend's Mooney with a cracked block on his angle valve IO-360.
Superior appears to have done their homework on the research and engineering. By engineering out the few failure points that were known on the Lycoming design, they're added value that's worth money to me. ECI was slow to own up to manufacturing defects in the cylinders of a friend's P-210 that later became an AD, and so I question their integrity as well. Your mileage may vary, of course. When the time comes, I anticipate that a Superior will be going in my -7A.
Dave Johnson
48V, Erie, CO
Cessna 182 owner
RV7A in progress
Old 09-04-2006, 12:08 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Default Superior 360 kit
Stephen,
According to Superior's website, they still sell the SL-360, which is the XP-360 as a box of parts, assemble it yourself.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 09-06-2006, 12:23 AM
osxuser's Avatar
Sweet! I can never seem to find info on kit-engines. Even ECi's website is vague about how to get one...
RV7 emp built
