08-26-2013, 04:44 AM
Cleco holder: Anyone try this?
I was thinking about a way to have easy access to clecos while using them.
Anyone ever use a shot gun shell holder on a belt? Like the one in the link below.
http://www.amazon.com/Allen-Company-...+shell+holders
This would keep them off the bench and they would follow you around your work to where you need them.
08-26-2013, 04:48 AM
Looks like a great idea. I will have to try it.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
08-26-2013, 06:03 AM
During the wing build (lots of clecos!), I used a cheap cloth nail apron. I think it was a give-away at the local McCoy's Hardware. Worked great.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
08-26-2013, 06:47 AM
What Larry said: I used a .99-cent cloth apron from Home Depot. It's got two compartments sewn in, so one side contains each of the two sizes of clecos you'll be using. The apron is less bulky, since it rides up against your waist. Cleco pliers fit right in too. I tried the shotgun shell holder approach first, and since it stuck out away from the belt, it was always banging into something and kind of in the way. Your mileage may vary, but the cloth nail apron is dirt cheap and highly effective!
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
08-26-2013, 06:50 AM
Back when coffee was sold in an actual can I saved a few 1 Lb Maxwell House cans (back before I upgraded coffee and a 1 lb. can of coffee still was an actual point).
Still have them full of clecos, still use them when needed.
But the nail apron idea seems like a nice idea.
08-26-2013, 07:27 AM
So did I! Worked great.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
08-26-2013, 07:39 AM
Me too, I think you have a winner!!. copper right, nickel left, or . . .
Bill
RV-7
Lord Kelvin:
08-26-2013, 08:44 AM
The cartridge pouch will work good, but you have to holler PULL every time you pry out a cleco.
Actual repeat offender.
08-26-2013, 08:59 AM
I used a 1 gallon bleach bottle with 6" hole cut in the side of the container, It still had the handle and holds about 200 clecos. The pouring spout holds 2 pair of cleco pliers.. Works good for me.
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
08-26-2013, 09:04 AM
Many become one...
I've found out recently, that proseal will quickly turn a pile of seperate clecos into one big glob of clecos. Then, you simply tote this giant ball around while working, pulling off the clecos as you need them. No need for a sack.
