Old 08-24-2013, 06:05 PM
scard's Avatar
scard scard is offline
Default How many hours should a prop control last?
I'm looking at a prop control cable where the last two end segments are severely 'wiggly'. I'm thinking it is not long before this cable comes apart. I already have new parts on order, but was curious. Are people getting 1500+hrs out of this cable? I've always said my objective is to wear it out, but just want to be sure I'm "doing it right".
Scott Card
CMW E-Lift
Old 08-24-2013, 07:24 PM
RV6_flyer's Avatar
Not sure what cable you have but I used an Aircraft Spruce cable and it has over 2,700 hour on it. The bolt is worn at the point where it goes through the governor arm but a new bolt got rid of all my wiggle.
(The ACS cable is a Teflon lined cable.)
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-24-2013, 07:33 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default My experience
This spring at 1000 hours I had to replace my prop cable in our RV7a when it started sticking. After replacing it with a new cable from Vans, I was able to lube it and it works on the bench.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 08-24-2013, 07:40 PM
scard's Avatar
Mine is a standard Vans cable. The part I'm concerned with is the articulated rigid steel segments between the governor bracket and the governor arm.
Scott Card
CMW E-Lift
