Old 08-24-2006, 10:25 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Tip-up canopy side seals?
I have a slight gap between the canopy skirt and side fuse decks in a few places -- enough to show daylight from inside the cockpit, and would like to seal it for appearance if nothing else.
I'm under the impression that some sort of rubber seal goes (or can go) between the canopy frame and fuselage deck -- but can find no mention in the manual or plans. I have a bunch of different rubber seals that came with the kit, I imagine at least some of them are for the forward canopy seals on the subpanel. Any tips?
Related canopy question: is there a trick to separating the gas struts from the little ball joint? I've tried pulling on them but they didn't break loose -- though I didn't pull that hard for fear of breaking the strut.
Thanks - Paul
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 08-24-2006, 12:12 PM
frankh's Avatar
frankh frankh is offline
Default Lever up the spring
that black spring steel thingy on the end of the strut. If you lever it up with a sharp pointy thing that will release the ball.
As tp seals, yes I never found reference to it either but I do see 5' of left over black seal that looks like its just made for the job...Stick it to the canopy frame, not the fuese side rail of course.
Frank
Old 08-24-2006, 01:38 PM
N523RV N523RV is offline
Banned
Paul,
Even what Van's provides you really isn't thick enough.. or at least in my case. McMaster has some that would work pretty good I think. I saw reference to them on Dan C's site. If you go to the McMaster catalog and look at page 3258 you'll see all sorts.
Old 08-24-2006, 04:19 PM
GaryK's Avatar
GaryK GaryK is offline
Default Canopy Seal
Roberta posted this a couple of years ago, it works perfectly
If you want something really nice for the sides, use
ALL STRIP WEATHERSEAL from Aircraft Spruce.
Part # 05-00898
Gary
N715AB
Old 08-24-2006, 04:27 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Thanks, Gary. It still works great. Stick it to the canopy frame. That way it is not as visible or likely to get damaged from feet and hands during entry and exit.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 08-24-2006, 09:49 PM
dan's Avatar
dan dan is offline
http://www.mcmaster.com/nav/enter.as...2&pagenum=3258
Push-On Edge-Trim Rubber Seal Bulb Next To Grabber, 1/32" Edge, 3/8" Bulb Width
That's the stuff I prefer...was 95 cents per foot last time I ordered it, and it works great. I like that it's a "bulb" seal rather than a solid foam pad. That way it can grow and shrink as needed as the canopy contracts in cold and expands in heat. And it doesn't apply any force against the canopy & side deck. The bulb compresses and it just rides there, filling the gap. The bulb is 3/8" but can compress way down without force. Good luck using 3/8" foam...it would be too fat.
I used a foam seal once and my canopy got stuck latched because of the decompression force of the seal.
Dan Checkoway RV-7
