08-24-2006, 09:35 AM
Using "quote"
Hi guys,
When using the 'quote' button, how do you delete some of a quote and only use a portion of a previous message. I tried it by deleting some of the message after pressing the button but it didn't work,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
08-24-2006, 09:39 AM
Originally Posted by pierre smith
Hi guys,
Make sure you preserve the stuff in the square brackets and you should be OK (I deleted part of your message in my quote)
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
08-24-2006, 09:44 AM
unqualified unfluencer
Originally Posted by DGlaeser
...snip... preserve the stuff in the square brackets and you should be OK (I deleted part of your message ...snip...
I usually try to put a ....snip.... in the preserved quote (like above) if I'm cutting stuff off, just leaving enough text to leave intact the theme of the thread. No right way of course...
b,
d
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Part time: Supporting Crew Member CAE Embraer Phenom 300 (E55P) @ KDFW.
- Occasionally: Contract pilot (resume).
08-24-2006, 12:07 PM
Dennis,
Do you mean that I place a [ at the beginning of what I want to quote and then ] at the end? I'm still somewhat confused.
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
08-24-2006, 12:15 PM
You're very close, Pierre.
If you 'reply' to a message by clicking on the QUOTE button down at the bottom right it will put in all the appropriate code and will make sense once you see it. I'm assuming you're hitting the 'POST REPLY' button instead of the 'Quote' button, of course. I could be wrong (often am <g>).
B,
D
Dennis,
08-24-2006, 12:27 PM
B,
D
Thanks Doug,
I do hit the 'quote' button like this but how do I eliminate some of the text?
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
08-24-2006, 12:50 PM
Just delete as you would any other. Just don't delete any of the [ or ] or the word QUOTE or /QUOTE.
B,
D
08-24-2006, 12:59 PM
Testing
B,
D
Thought I Should test the quote feature while the thread is going.
08-24-2006, 01:30 PM
Modifying quoted text
Dennis,
Pierre,
When you hit the quote button, the original message appears between a special set of text "QUOTE" and "/QUOTE" that are enclosed in square brackets. Those are HTML commands which format the display of the message. What I meant is to leave the special text alone - but you can modify the text in between them.
Your new message is added below the "/QUOTE".
If you want to get fancy you can embedd HTML commands in your message (Note: I put an "I" in square brackets before fancy and a "/I" in square brackets after it to make it italic).
You can use the "Preview Post" button to see your formatted message before you submit it if you want - and make changes until you get what you want!
Dennis Glaeser CFII
Rochester Hills, MI
