08-21-2013, 01:32 PM
Best baffle material to use
I need to replace some of the baffle material on my engine after about 400 hours and was wondering what is the best material to use. I have used the standard Vans supplied black rubber and it has held up pretty well with the exception that I think it has formed a curve to the point that is not sealing well against the cowl. I put a flash light inside and could see light coming thru then hooked up my vacuum shop as a blower and air was sipping thru, so I am thinking of replacing them.
Thoughts and ideas?
Thanks in advance
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
08-21-2013, 01:34 PM
Senior Curmudgeon
I used the orange stuff from Aircraft Spruce------like it
I have a lot left over if you want to stop by and get some to play with. Also have a lot of the black stuff from Vans if you want it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
08-21-2013, 01:45 PM
Thanks Mike, I really appreciate it.
If you don't mind, I will stop by to check it out.
sent PM.
Mehrdad
Dues paid
08-21-2013, 02:48 PM
I noticed that the orange stuff comes in different thicknesses.
Which thickness is best?
Thinking of upgrading my baffle seals
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
08-21-2013, 05:30 PM
Love the idea of a light -3
But an -8 is much more practical
08-21-2013, 08:06 PM
I used the McFarlane material on both sides and across the back during my initial build. After almost 500 hours, its holding up well on the sides but deformed quite a bit on the back.
I replaced the McFarlane with the thinner silicone material that ACS sells. I also replaced the Vans material that I used on the front-center baffle. The thin ACS material is much heavier than the stuff from Vans. If you get the baffle material from Spruce, I see no reason to use the thick stuff.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
08-21-2013, 08:30 PM
Another vote for McFarlane
You won't regret the price and you'll love the product.
Apart from the quality make up of this baffle material, it is coated with some slick silicone material to minimize the transfer of vibrations to the cowl.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
08-22-2013, 07:01 AM
Great Timing
I am at the baffle material time.
Baffles are on the engine but not trimmed yet.
Getting ready to start on cowling.
How much material needed.
Will the 3" do the job and if so how long of a piece.
Might as well do it improved the first time.
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2020
08-22-2013, 10:35 AM
I hear there are after market plenum top for the RV 7 & 9s. Anybody know where you can purchase them?
Ron
08-22-2013, 10:58 AM
Senior Curmudgeon
Ron, talk to Henry B about them.
Mike Starkey
VAF 909
Rv-10, N210LM.
