08-21-2013, 01:00 PM
Propeller Shaft Seal????
Does anyone know the diameter of a Lycoming 320 propeller shaft so I can purchase a seal . Also I would llike to know what the diameter of the hole that the seal sets in on the motor...
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
08-21-2013, 01:11 PM
Senior Curmudgeon
Are you planning on getting something other than Lyc part???
Regular automotive etc. seals will probably not work, as the seal has to stretch over the prop flange.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
08-21-2013, 01:13 PM
Yep - been there done that 6-8 times. Buy the Lyc (or equal) seal. And follow the prescribed installation procedure. There are split seals available (can split it yourself). Works 99.99% as good as a 1 piece if done right, and much easier to install.
08-21-2013, 01:14 PM
Seal
This is a Lycoming part, you do not need sizes. Two types, split or solid. If you have a two piece retaining plate with four bolts it is likely split type. There are oversizes on the outside diameter.
08-21-2013, 03:07 PM
VAF Moderator / Line Boy
Not everyone flies behind a Lycoming guys - I think this is a unique engine installaiton if I rememebr corectly. Unfortunately, I don't know the measurements he needs, but maybe someone else can actually give him the dimensions he seeks.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
08-21-2013, 03:22 PM
Feed it!
Any Navy guys remember that joke? "go feed the shaft seal"???
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
08-21-2013, 04:15 PM
Yup! Those and the Naughas.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
08-22-2013, 06:03 AM
I can't remember if you feed it with a bucket of steam or relative bearing grease!
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
08-22-2013, 07:46 AM
08-22-2013, 07:48 AM
I'm not Navy but my son is.
I assume the above is where the hides are grown?
My son did comment on the common search for CPO nuts in the maintenance hangar.
Bill Pendergrass
ME/AE '82
