Presision Airmotive Eagle EMS W/ GRT EIS
Having trouble with RPM and FF output using Eagle EMS and GRT/EIS, IO360. Have received difference answers from PA and GRT. ( Both companies have been great in trying to resolve the issue.) I used 1K resistor, one each, RPM, FF + 12V, as per PA...Allen. Zero reading on EIS for both, engine running , Talked to Dennis at PA was told that was wrong to use +5V input as the Eagle system does not like 12V. Before changing I called Nick at GRT he stated that perhaps using +5V their EIS may not recognize the lower voltage, he's checking and now waiting for an answer. While waiting I did some more reading of info from PA. Found a statement telling to use a 5K resistor and +5V input for RPM and FF. Before I start changing things around. Is anyone using Presision Airmotive EMS and GRT EIS and getting RPM and FF on the EIS from the EMS, if so, I would appreciate any help getting this setup. (resistor's used, voltage etc.) Thanks in advance, Terry
Again, both companies have been great, I'm just a little comfused.
