08-21-2013, 07:11 AM
Tip-up top deck clean-up...
700 hours of grabbing and foot dragging on the top deck from getting in and out had really worn the paint significantly. Worse, when it was hot outside the rattle can paint that I used that was being worn away was no longer holding up to routine use or cleaning.
The Vans wing walk is very thin, sticks well, is very durable, and feels nice to the touch. I ordered up a single blank sheet and cut some pieces to cap the decks. It came out great; should have done this sooner
You don't see it in this shot but the material rolls over the inside about a half inch.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
08-21-2013, 07:28 AM
it did look and feel nice, great way to finish that edge.
Might do it to Aurora, if my paint ever wears out.
08-21-2013, 07:31 AM
Had the same thought
Looks great, I was thinking of doing the same. However I was hoping to find a dark grey color? Any sources?
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
08-21-2013, 07:39 AM
skateboard shops have the same material in many colors.
I used clear skateboard stuff for my wing walk pad. Looked great over the yellow wing....until I started using it. I can not get it clean anymore and it shows dirt badly.
08-21-2013, 07:40 AM
If you are looking for other colors, check for "skateboard anti skid"
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Super Idea
I've been trying for years to come up with an easy way of refinishing up my side rails.
After over 20 years, they're showing more than a little wear.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
08-21-2013, 01:19 PM
Ace Hardware has some in grey, though not terribly dark. Has worked fantastic on my wing walk area and also just forward of the stick where I step when getting in.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
08-21-2013, 02:17 PM
I hardcoated mine before riveting. I'll be very surprised if I ever scratch it.
Bill Pendergrass
ME/AE '82
