Something to try...
I am not at this stage yet so I don't know if it will work or not. However, I have cured RFI problems in the past with the addition of a simple ceramic disk .01 or .001 micro farad capacitor. My ham radio rig was bleeding over into my stereo. I placed one of these caps right across the speaker leads physically at the speaker and the problem went away.
Bascially, a capacitor looks like an open circuit to low frequencies (i.e. DC power sources, audio frequencies, etc.) and they look like a short to high frequencies (i.e. radio frequencies (RF)). You can try placing the capacitor with one leg to ground and the other to the wire that you think may be picking up the RF. For instance, if you think the RF is coming in on the power lead, place the capacitor between the plus power lead and ground. If you think the RFI may be coming in on a sensor lead, place the cap between the sensor lead and ground. (NOTE: take care doing this to any sensor lead that is sensing something that changes very fast; I think trim and flap position indicators would be pretty safe). You want to do this as physically close to the affected instrument as possible. Preferrably, attach the cap right on the back of the instrument being affected. Keep the lead lengths as short as possible.
Long wire runs act like antennas and pick up RF. The cap will short the RF to ground.
You can get these caps at Radio Shack or order them online. They should not cost more than a couple of bucks. Don't get electrolytic caps. Just get el-cheapo ceramic disk (non-polarized) caps.
Like I said, I have not tried this with aircraft instrumentation. But it wouldn't be difficult to give it a shot.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
