Old 08-18-2013, 06:17 PM
Default Need alum tube to plastic hose fitting
I want to install the DIY AOA that Mel Asberry has but I need the coupling that SafeAir1 recommends to connect 1/4" aluminum tubing to plastic tubing. Avery is out of stock. Anyone know who else might carry such a thing?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 08-18-2013, 06:26 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Stein might have the coupler as well - I *think* that is where I got mine.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
crabandy crabandy is offline
Default Steinair?
Are these what you are looking for?
http://www.steinair.com/storedetail.cfm?productid=532
Old 08-18-2013, 06:39 PM
This is what I'm looking for:
Bob Collins
St. Paul, MN.
Old 08-18-2013, 07:01 PM
Sam Buchanan's Avatar
been here awhile
Bob, cut a 3" length of hose (rubber, flexible vinyl, etc) that has the same ID as the OD of your tubing. Slip it over the aluminum and plastic hose and you have a coupling.
I've used this technique for over 20 years and it makes a reliable, airtight connection. It works so well you will probably have to cut the "coupling" if you need to disconnect the hoses...but you know how to make a new one.
[thread moved to General Discussion so it will be in the archives]
Sam Buchanan
RV-6
Fokker D.VII replica
Old 08-18-2013, 07:05 PM
Mel's Avatar
Mel Mel is offline
I agree with Sam. Actually all of my pitot and AOA connections are just slip-on.
Pressures are so low that it doesn't take much to seal.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-18-2013, 08:05 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Third vote for the simple rubber tube sleeve - been doing it for decades, and never a problem.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-18-2013, 08:15 PM
deek deek is offline
My 31 year old LongEZ has vinyl tube couplings that are holding up perfectly. If so inclined, use a couple of small ty-wraps to cinch down lightly on the vinyl. Low weight, low cost and simple.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 08-19-2013, 02:42 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Easier than tyraps, just slide a slightly undersize O-ring over the tube at each slip joint.
It will exert an even pressure around the plastic tube circumference unlike a tyrap.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-19-2013, 07:59 AM
Bayou Bert's Avatar
Bayou Bert Bayou Bert is offline
Default Don't Beat Me Up
Vinyl tubing....any special kind?
Get it from?
A couple of inches each way?
The kit I bought has "hard pipe" static run to the cockpit area.
First time I have seen that, it's alum tube...1/4" OS dia.
It is not Van's static kit. The two ports, on the outside skin are about
silver dollar size with four rivets each.
The tee for the ports only sits about 2" above the ports.
Sure would like to convert to plastic to make all the connections easier
All comments and direction greatly appreciated.
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2020
